03-24-2019
15:18
11:10
03-24-2019
15:18
11:10
The small strap that holds the excess portion of the wrist band in place has split. Can I purchase this item separately?
03-24-2019 23:47
03-24-2019 23:47
Hi @OurZoey If you mean the little keep loop that holds the loose end ofbthe strap to the watch band, then the answer is no. You need to buy a whole new watchband From fitbit https://www.fitbit.com/store or a third party one.
Helen | Western Australia
03-24-2019 23:47
03-24-2019 23:47
03-25-2019
07:30
11:03
03-25-2019
07:30
11:03
A warm welcome to the Community @OurZoey and @NellyG thanks for the input.
I am sorry to hear about what happened with your strap keeper. Upon checking with our support team, I was told that you have already contacted them. I know they will be glad to help you out and provide you a solution, just keep an eye on your inbox for further assistance.
Let me know if you need anything else. ![]()
Best Answer09-23-2020 07:24
09-23-2020 07:24
Ajejandra,
I have the same problem with a Charge 3 purple that I bought for my wife 6 months ago.
I contacted support and they told me I had to buy a new strap - this is shocking, we have had 3 Fitbits and expect better than this.
What is the point of paying over £100 for a Fitbit only for poor quality loops like this to break. She cant wear the Fitbit outside now in case it falls off.
I have to disagree with your comment that support will be glad to help out and provide a solution, all they did with me was try to sell me a new strap! And what happens when the loop breaks on that? Buy another, then another?
Cant tell you how let down I feel
Eddie
