11-10-2018
14:38
15:03
11-10-2018
14:38
15:03
Has anybody else got a problem scrolling through the screens on their Charge 3? Although not scrolling down through the screens / features might be more appropriate. I read the help document and did exactly as it said but when I move my finger down the screen it only shows the next Fitbit features intermittently, eg steps, number of staircases, calories I’ve used etc.
Also, sometimes the watch screen goes off when I touch it and am trying to move to the next features, even after 2 or 3 seconds.
11-10-2018 18:38
11-10-2018 18:38
Im not sure I understand your question. Are you having trouble moving from one item on the today screen to the next? That is what I understand by scrolling. Or are you trying to change the order of the list?
Helen | Western Australia
Best Answer11-10-2018 21:28
11-10-2018 21:28
Thanks, just trying to move from one item to the next on my watch. Not trying to change the order.
06:42
08:04
11-11-2018
06:42
08:04
It's great to welcome you @SueAMarshall and @NellyG thanks for stopping by.
I appreciate all the efforts in trying to fix this issue. Please confirm these are the steps you are trying to restart your tracker:
Let me know the outcome. ![]()
11-12-2018 21:19
11-12-2018 21:19
Thanks, I did exactly as you said but it hasn’t worked. It’s very disappointing as I find it very frustrating and will be sending my fitbit 3 back
Best Answer11-16-2018 04:16
11-16-2018 04:16
This worked for me. When all else fails, reboot.
11-18-2018
03:04
08:04
11-18-2018
03:04
08:04
Thanks for the update @SueAMarshall and it's great to welcome you @LT88.
@SueAMarshall upon checking with our support team, I was told that you have already created a case with them. I know they will be glad to help you out and provide you a solution.
@LT88, I am glad to hear that the instructions provided worked and that your tracker is working properly. If there is anything else we can do for you, do not hesitate to post it.
Happy stepping! ![]()
Best Answer12-02-2018 14:34
12-02-2018 14:34
I had the same issue today just tried the reset and the instructions worked.
12-03-2018
03:48
08:03
12-03-2018
03:48
08:03
It's great to have you on board @macz-fitgurl and to hear that the instructions provided worked and that your tracker is working now. Let us know if there is anything else we can help you with.
Keep the stepping up! ![]()
Best Answer12-03-2018 14:44
12-03-2018 14:44
My original Fitbit 3 did not work no matter what I did. However I got in touch with Fitbit and they sent me a new Charge 3 once it was determined that the one I had was faulty. Now very happy with the replacement.
Best Answer12-03-2018 14:47
12-03-2018 14:47
My original Charge 3 was determined to be faulty and a replacement was sent which works perfectly. More than happy with the Fitbit.
Best Answer12-03-2018 17:56
12-03-2018 17:56
My wife had the same issue but the reboot worked for her. But good to hear you got a replacement. Fitbit support is really I have gotten a replacement in the past.
Best Answer05-20-2020 00:19
05-20-2020 00:19
I charged my Inspire all day. Still didn't scroll. Then I plugged it back in and held down the button. After the screen went dark I counted 8seconds...waited for the smiley face to appear. Thankfully it did! My Fitbit is back up and running. Thanks for the directions.
Does this restart need to be done periodically? Does this happen on all models?
