02-06-2020
09:11
15:03
02-06-2020
09:11
15:03
I’ve tried everything from shutting it down multiple times to cleaning and leaving it alone...nothing is fixing it. I’ve had it for about 6 months and never had a problem! :’( I’ve kept from showering or swimming with it even though it technically is waterproof. So I don’t know what’s happened or why
02-06-2020 11:20
02-06-2020 11:20
02-06-2020 11:20
Contact Customer Support.
Best Answer02-06-2020 11:43 - edited 02-06-2020 11:44
Hi there @VictoryBelle, welcome to the Community Forums. Thanks for the details provided about your Charge 3's screen and for taking the time to troubleshoot it prior to posting here.
I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
Thanks for your help @SunsetRunner.
Let me know if there's anything else I may do to help you.
Best Answer02-06-2020 12:22
02-06-2020 12:22
I am having same issue. White lines on screen - blocking information. Please start a case file to get this cleared up. Thanks
Best Answer02-09-2020 17:56
02-09-2020 17:56
I'm having the gray screen and lines issue too! Did the "long restart" to no avail.
Best Answer02-10-2020 06:18
02-10-2020 06:18
Customer service -via chat unable to resolve issue. Check if your Fitbit is in warranty Mine is being replaced at no charge.
Best Answer02-10-2020 11:13
02-10-2020 11:13
Hi there @jacquix, welcome here. Thanks for troubleshooting your Charge 3's screen prior to contacting us.
Since this sounds a bit more serious, I've created a support case on your behalf - you should soon receive an email from Customer Support at the email you used to register with the Community forums. If you have any questions, don't hesitate to let me know.
Hey @mjgowder, thanks for stopping by. I'm glad to hear that our Support Team replaced your Charge 3. 😉
Don't forget that you can set up your new Charge 3 on your currently Fitbit account by following the steps below:
I'll be around if there's anything else I may do to help you.
Best Answer04-27-2020 14:20
04-27-2020 14:20
I'm having the same issue! I've also had mine for 6 months. Never showered with it. Never swam with it
Best Answer04-27-2020 15:08
04-27-2020 15:08
Mine did the same thing randomly yesterday morning! Never showered or swam with it, but now the display is all white and grey lines. I did try the short and long restarts but nothing has helped.
Best Answer04-27-2020 16:02
04-27-2020 16:02
