10-03-2019
06:55
10:43
10-03-2019
06:55
10:43
My Charge 3 will not pair with my phone. Worked fine until i noticed about 2 weeks ago was only syncing current day and not tracking sleep. I have deleted the app restarted my phone reinstalled the app restarted my Charge 3 and have done all the troubleshooting and now it won't even pair with my phone. It sits on the same sorry we're having trouble screen forever and it is now losing time. It is not even a year old very frustrating.
10-04-2019
05:09
07:39
10-04-2019
05:09
07:39
A warm welcome to the Community, @Jillhop84.
I am sorry to hear about your frustration and appreciate all the efforts in trying to fix this setup issue. I recommend taking a look at the help article: Why can't I set up my Fitbit device? and follow the instructions provided there.
Let me know the outcome.
I have tried all the trouble shooting steps several times with no luck. It still will not pair or finish set up.
Hello there @Jillhop84, thanks for getting back and following the recommendations provided above.
While reading your post I was wondering if the mobile device you're syncing with is included in our list of supported devices? You can see the list at: Which phones and tablets can I use with my Fitbit watch or tracker?
Please keep in mind that when a device is not supported we cannot guarantee its functionality with the Fitbit app. It might work at a certain time and then it can stop working out of nowhere after an update. This is because the app is not optimized to that device and any change could impact the performance.
Besides the steps you've tried so far, I'd suggest to try the following in the order shown:
1. Remove the Charge 3 from the phone's Bluetooth settings.
2. Turn off other Bluetooth connections when not in use.
3. Plug it into the charging cable and open the Fitbit app.
4. Setup your Charge 3 as a replacement.
Give this a go and let me know the outcome.
Best AnswerI have tried all the above mentioned and no luck. Just sits on sorry we're having trouble screen. It is a note 5 and should be compatible. This is very frustrating as it previously worked fine now it will not pair no matter what. And i have done all the trouble shooting steps several times each.
Hi @Jillhop84, thanks for letting me know the outcome.
Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
Let us know if there's anything else we may do to assist you in the meantime.
Best AnswerI am having the same issues and I have tried everything that was suggested. My Charge 3 was connected to my phone but was never syncing. I did as suggest and unpaired it, now it will not pair. This is beyond frustrating
Hi @jweigel76, welcome on board. I totally understand where your frustration is coming from. Thank you so much for following the recommendations provided in the forums.
Can you please confirm if you followed all the steps I recommended here? Did you check in your phone's Bluetooth settings that the Charge 3 was no longer paired? Also, may I have the model of your phone?
I'm looking forward to your response, keep me posted.
Best AnswerI've had exactly the same issues as you and the previous users , i uninstalled the app and reinstalled but only gets to the same place as yours. Your right, very frustrating and I have now wasted so much time
Best AnswerI am also having the same trouble with my charge 3. It was working up until the new update. I have tried all the steps you've mentioned too. It's is very annoying. Thank you for you help in advance.
