03-19-2021
10:33
07:45
WilsonFitbit
03-19-2021
10:33
07:45
WilsonFitbit
My charge 3 is not syncing with my Ipad 6. When I forget device, nothing happens and I can not get the connection back. Is there a hardware problom? Do I need to return it?
Hello @Kishp, @Dknox37 Welcome to the community forums! Thank you for the troubleshooting steps you've tried prior to posting!
If you have unpaired your Charge 3 devices, make sure that you performed the exact steps below to forget the device:
*On your phone, tap Settings > Bluetooth > the information icon next to the name of your Fitbit device > Forget This Device.
*Open the Fitbit app and set up the connection again. You should receive a message asking you to allow your Fitbit device to pair with your phone. Tap Pair to approve the request. You can also find more details here.
On a side note, I recommend performing a restart by following the instructions below:
You can also restart your tracker from your wrist. For this, open the Settings app > The settings app icon used on many Fitbit trackers, which looks like three horizontal sliders and tap About > Reboot Device.
Lastly, please note that your Fitbit Charge 3 devices should work with any device that meets the requirements listed here.
Hope this helps!
Hope this helps!
Best AnswerI have done all of those things several times and it will only pair for about 30 seconds and that it unpairs again. Both my Fitbit and iPhone are running on the most recent update.
Hello @Cstarks Welcome to the community forums! Thanks for following the suggested troubleshooting steps!
I was able to see that you have reached out to our Support Team. Since you have received assistance from them, I suggest you to update your case if you require further assistance or if you have any additional questions about the outcome of your case.
Have a great day!
None of these steps worked. My charge 3 is behind on time, and absolutely wont pair with my device, I though it was my new phone but the phone paired with my car so am thinking the Charge 3 is defective AGAIN. HELP
Hello @robinlynsip Welcome to the community forums. @Cstarks It's great to see you around and I'm glad to know that you're back on track.
@robinlynsip I'm sorry for the experience and thank you for the information. I was able to see that you have reached out to our Support Team and they have provided assistance and information. Since you have received assistance from them, I suggest you to update your case if you require further assistance or if you have any additional questions about the outcome of your case.
See you around.
Best AnswerI was having that problem along with other issues. What I did was do a factory reset of the Fitbit. Everything was back to normal. One suggestion, wait until midnight to do the reset so that you don't lose the work you put in that day.
03-30-2021
04:40
05:23
WilsonFitbit
03-30-2021
04:40
05:23
WilsonFitbit
I am glad your situation has been remedied. I am still working toward satisfaction. They determined my charger was out of warranty Purchased Feb 7, 2020, BUT that one died in Sept 2020 and they sent me a replacement. (in retrospect I should have opted for the 50% off another tracker instead) So the Charger that is not good and is literally only 6 months old. I am annoyed that the resolution to repeated failures is a code for 35% off that won't work. Meanwhile I am without a Tracker that works, missing out on points etc. Husband wants me to go with another brand, and I am close. Feel like the quality of Fitbit Trackers has gone way down. I am not sure what I will do.
Thank you for attempting to help, my problem was it will only successful resetting (after many steps) for one sync right then, then it would not sync again. It was sadly frustating and annoying.
Moderator Edit: Merged posts/word choice
04-01-2021
05:28
04:52
04-01-2021
05:28
04:52
@Santinaburton @Cstarks Welcome to the community forums. Thank you for your great input.
@robinlynsip I apologize for the experience and thank you for taking the time to provide your feedback. Please note that our team is always working to enhance your experience and your feedback is a big part of that process.
I was able to see that you're working with our Support Team towards a resolution. I suggest you to keep an eye on your inbox since they should get back to you with more information.
On a side note, I'd like to let you know that replacement devices don't renew the warranty period of your original purchase. For more information, please check: https://www.fitbit.com/global/us/legal/returns-and-warranty
See you around.
04:02
04:51
04-02-2021
04:02
04:51
@Santinaburton I'm happy to know that the inconvenience is resolved!
Hope you can continue tracking towards your fitness goals!
Have a great day!
Best AnswerTry doing a factory reset of the fitbit. That correct my problem. One suggestion...wait until midnight. That's when everything resets back to zero. That way, you don't lose anything you did for the day.
07:23
04:51
04-08-2021
07:23
04:51
@robinlynsip I'm sorry for the experience and thanks for your feedback. @Santinaburton It's great to see you around and thanks for your input!
If you still experience any inconvenience with the discount code, I suggest you to reply back to the case that you have with our Support Team so they can continue assisting you.
Or you can post through the Other Versa Smartwatches board if you have additional questions.
See you around.
