01-22-2020
12:48
17:35
01-22-2020
12:48
17:35
We have tried on multiple occasions to try to get it to charge. It simply will not do anything. Please Help!!!!!
Hi there @DeniseDash, welcome to the Community Forums. Thanks for the details provided, I'll be glad to help you.
Please restart your Charge 3 by following these steps, then charge your tracker once again for at least 1 hour.
If the restart doesn't work and the display is still not turning on after performing the steps above, please take a look at the help article: Why isn't my Fitbit device's battery charging?
We recommend to charge your Fitbit via the USB port over a wall adapter. However, it is also possible to charge your Fitbit tracker with a UL certified wall adapter. For best results, don’t leave your device plugged in on the charger longer than overnight.
Tips to better charge your Fitbit:
For charging purposes, your charging cable can be plugged into any USB power source, including but not limited to:
Keep the charging contacts on the back your device and the pins on the charging cable clean and free of debris. For more information, see: How do I clean my Fitbit device?
Let me know the outcome, I'll be around.
