01-31-2020
07:38
17:16
01-31-2020
07:38
17:16
I tried a hard reset and it has not resolved the issue. This is my second Charge 3, FitBit replaced my first one in July as the original screen started getting lines through it shortly after I bought it. This Charge 3 won't hold a charge. When I plug the Charge 3 into my computer it appears to be charging. After some time the watch will come back on and say it has a full charge. But when I go to use it the charge disappears within minutes and the watch gives me all the warnings, then vibrates and goes dead.
02-01-2020 08:41
02-01-2020 08:41
Hi there @Playnejayne, thanks for stopping by and for the details provided about your Charge 3's battery behavior.
As per the description, it seems that it has insufficient power source. Where do you charge your tracker? Have you checked if by any chance the USB port or outlet is faulty? If you haven't done so, try a different port. A UL-certified wall charger will also work. Don't use a USB hub. You can find more detailed information in the help article: Why isn't my Fitbit device's battery charging?
Also, I'd like you to review the tips and recommendations provided in the article: Can I extend my Fitbit device's battery life?
Give this a go and let me know the outcome, I'll be around and glad to further help you.
Best Answer02-10-2020 14:55
02-10-2020 14:55
Hi MarreFitBit,
I charge my Charge 3 on my computer and have tried all the usb ports. It is still doing the same thing, looks like it's charging, says it has a full charge, then I disconnect it from the computer and within 30 minutes is back down to 3% charge.
thanks for your assistance,
Jayne
Best Answer02-11-2020 09:17
02-11-2020 09:17
Hello @Playnejayne, thanks for getting back and letting me know the outcome of the steps recommended.
I went ahead and created a case for you with our Support Team. Someone will reach out to you soon to offer their assistance. Please keep a lookout in your inbox to the email address associated with this account.
Let me know if there's anything else I may do for you in the meantime.
Best Answer02-11-2020 11:31
02-11-2020 11:31
This is happening to me too, ever since I updated the software the other day. Will not hold a charge, even though I have plugged it in many places. As long as it’s plugged in, it is on, but shows a 0 battery.
Best Answer02-11-2020 11:38
02-11-2020 11:38
Hi there @HayleyJay, welcome on board. Thanks for the details provided about your Charge 3's battery behavior.
Before considering other options, can you please confirm that you've followed the tips and recommendations provided here?
I'm looking forward to your response, keep me posted.
Best Answer02-11-2020 11:56
02-11-2020 11:56
Hey there! Yes, I read all of those and they aren’t really relevant. Btw, I work in SF SOMA if for any reason you want me to bring it in as an example, assuming you’re having this issue with others as well.
