04-29-2020
06:58
11:42
04-29-2020
06:58
11:42
I have not been able to sync since April 25, 2020. I have no battery charge on my Charge 3, I have connected it several times to charge the unit and it still will not charge. I cleaned the gold on the watch several times, I changed USB ports and device I am using to charge. It still shows zero charge. I can't turn it on and off, there is no vibration from the watch. I can't get into a live chat. Suggestions?
06-10-2020 12:10
06-10-2020 12:10
Welcome to the Community, @DKRZYNSKI.
Thanks for troubleshooting this battery issue. Keep in mind that if your device doesn't have charge, it won't be able to sync.
Also, upon checking with our support team, I was told that you have already contacted them. I know they will be glad to help you out and provide you a solution, just keep an eye on your inbox for further assistance.
In the meantime, let me know if you need anything else. 🙂
Best Answer06-21-2020 16:32
06-21-2020 16:32
About a week ago (before June 15th approx) I noticed that my Charge 3 wouldnt charge, I tried charging it on and off a few times during that week before the battery got down below 15% and I tried it again for what I thought would be a final attempt, and it randomly worked and I got up to 100% battery. However since then, every attempt to charge has failed, and it finally went to zero while out on a walk this evening. I use the same USB port to charge my fon so I know thats not the issue. And it doesnt seem to be the FitBit cable as there wasnt even a flicker when moving it around to ensure it has good contact. I cleaned the contact points aswell just in case. What can I do now? Am fairly certain my warranty is just finished this month as I started using it around June 1st 2019. And annoyingly I had another problem when it stopped working for almost a week about a month ago back before the warranty was up and I didnt send it back, having finally gotten lucky (as I thought at the time) when it randomly started working again after a few resets.
Best Answer06-21-2020 18:21
06-21-2020 18:21
