Charge 3 won’t charge
I am having the exact same problem. It would charge intermittently if I cleaned it and applied all the suggested "fixes" (though this wasted a lot of my time) but now none of that helps and it won't charge at all. As with the others, this problem developed when the charger was just over a year old. What to do now?
Moderator edit: format and label.
1 REPLY 1
Thanks for getting back to us and for mentioning that you have applied the suggested fixes to charge your Charge 3 battery @SunriseRun482
I noticed that you already got in touch with our support team and they already assisted you.
Keep on visiting the forums.
