03-03-2019
19:20
11:22
03-03-2019
19:20
11:22
I can not scroll to any other screen. It is just showing the time screen. I’ve tried numerous times to reset it to no avail. What other options are there? Thank you
03-04-2019 03:51
03-04-2019 03:51
It's great to welcome you @Jover24.
I appreciate all the efforts in trying to fix this swipe issue by yourself. Please confirm these are the steps you followed in order to restart your device:
Hope to hear from you soon. ![]()
03-04-2019 06:28
03-04-2019 06:28
Sorry for the delay. This is what I’ve tried as I read it on the message board.
Is is there something else I can try
Best Answer03-06-2019 03:03
03-06-2019 03:03
Thanks for the update @Jover24.
Since the restart process didn't work, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
Keep me posted. ![]()
Best Answer03-06-2019 05:31
03-06-2019 05:31
Best Answer03-06-2019 06:38
03-06-2019 06:38
Hi Jover24,
What did your husband do to able to fix it? I have same problem and re-boot don´t help.
Best Answer03-06-2019 14:29
03-06-2019 14:29
Best Answer03-07-2019 03:52
03-07-2019 03:52
Thanks for the update @Jover24 and @Takariina welcome to the Forums.
@Jover24, it's great to hear that your tracker is now working properly. If there is anything else we can help you with, do not hesitate to post it.
@Takariina, have you tried performing a long restart:
Best Answer03-07-2019 04:39
03-07-2019 04:39
Best Answer03-08-2019 03:09
03-08-2019 03:09
Thanks for the update @Takariina, upon checking with our support team, I was told that you have already created a case with them. Please stay tuned to your email to see the steps to follow.
See you around. ![]()
Best Answer01-29-2020 18:49
01-29-2020 18:49
I always forget to be plugged into the charger and computer when I try to reset. And when I do those things and hold the button for 8 seconds, it resets. Smiley Face.
Glad this question is still here. I can come back to it, see the response, do the steps. And Voila!! Smiley Face pops up. And swipe works. Thank you AlejandraFitbit.
