09-15-2019
14:07
10:43
09-15-2019
14:07
10:43
All of a sudden, I cannot swipe the screen on the actual device. It still tells me the time, but I can't swipe to the left for the clock or alarms, or up to check my steps. Or anything. What could be the problem, and how do I fix it?
09-15-2019 18:14
09-15-2019 18:14
Hi @brandicandy0825 Try restarting the Charge 3 several times and also try a Long Restart. If neither of those fixes it please come back here.
CHARGE 3 LONG RESTART
Plug the device into the charging cable. While the device is plugged into the charging cable, hold the button down for 15 seconds. Remove your finger from button. Note: Device won't have a smiley face icon and should be off with a black screen. Remove the device from the charging cable. Plug the device into the charging cable again. The smiley face icon appears on the screen.
Helen | Western Australia
09-16-2019
10:00
08:51
09-16-2019
10:00
08:51
A warm welcome to the Community, @brandicandy0825 and @NellyG, thanks for the input.
I was able to see here that our friend @NellyG provided some instructions in order to fix this swipe issue. Was this the answer you were looking for? If it was, I recommend marking the answer given as a solution. By doing this, other users with the same inquiry will be able to find a faster response.
Now, if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out.
Best Answer09-17-2019 02:06
09-17-2019 02:06
Hi Prem Nath,
We'd be glad to assist you with the Blaze's cracked screen issue.
Please be advised that cracked, scratched screen or any cosmetic damages is not covered with Fitbit's limited warranty. For more information about our warranty policy, you may visit https://www.fitbit.com/legal/returns-and-warranty.
To confirm your the tracker's warranty status. Please let us know the following information:
-When you purchased the Fitbit device (or if it was a gift, when you received it)
-The retailer where you purchased it (if you purchased from fitbit.com, please provide the email address used at checkout)
-Country where you currently live
-If the device is from an employer, let us know the company name and when you received it
We look forward to hearing from you. Let us know if you have additional concerns.
Sincerely,
Genesis D. and the Fitbit Team
Best Answer01-11-2020 09:35
01-11-2020 09:35
I had my Charge for one day less a month and it wouldn't swipe left or right of up and down. I went to the fitbit site and chose the charge 3 icon. I typed in the issue and found a lovely had the same issue. She said to connect the device to the charger and hold the button down for fifteen seconds. The screen went blank for about 5 seconds and then the smiley faced appeared. This reset my fitbit and now it is working again.
