08-14-2019
16:32
10:43
08-14-2019
16:32
10:43
I bought a Fitbit Charge 3 as a backup for my Ionic (every 9 months or so the Ionic fails, apparently the battery stops working, so I have to send it for replacement under warranty and that takes about 2 weeks, and I can't stay without a Fitbit for 2 weeks).
Now that I got my replacement Ionic from Fitbit, I want to shutdown the Charge 3 to protect its battery while I'm using the Ionic. How can I do that?
Although some fitbit models have a shutdown option, the Charge 3 isn't one of them.
What I do with my spare fitbit is to charge it when I charge my main fitbit. A bit of a hassle but probably better for the battery.
Best AnswerActually, although Fitbit claims the Charge 3 can't be shutdown, I was able to shut it down using the instructions from a YouTube video:
- start charging it;
- press and hold the side button through the hole in the charger, make sure you don't release it;
- after about 8 seconds a progress indicator will show;
- after about 6 seconds, once it reaches 100%, you can release the button;
- remove Fitbit from the charger, the progress indicator will disappear, and the Charge is off now.
If instead it shows a smiley face at the end of the process, then the procedure failed, and you need to try again.
Video here: https://www.youtube.com/watch?v=ijnofRhSzaI
Not sure why this procedure is not documented by Fitbit and they claim it can't be turned off.
I've moved your charge 3 question out of the Charge forum. The Charge hasn't been sold for 3-4 years.
Best AnswerIn that case you should move my question back, because that is incorrect, the Charge 3 is still being sold today. I bought one just 6 months ago, and I can still buy one today. It even shows on your site as "In stock".
Later edit: Nevermind, I misunderstood what you did, I assumed you moved it to some kind of archive.
Best AnswerI moved it out of the Charge forum and into the Charge 3 forum.
The Charge doesn't have heart rate.
Best AnswerI can't get this to work. I'm not moving or anything. It start with the little bar across the middle then goes to the smiley face.
