11-03-2020
07:11
13:03
11-03-2020
07:11
13:03
11-03-2020 12:32 - edited 08-23-2025 13:35
Hi there @Deb-Paul, welcome to the Community Forums. I'm sorry to hear about the syncing difficulties you've been having with your Charge 3, I understand where your concern is coming from and how you must be feeling. Thanks for already trying to solve the issue prior to posting here.
I've seen that you contacted our Support Team regarding this and they tried helping you. If you have any questions about the resolution of your case, feel free to contact them back for a further explanation of the information you were provided or you can also check our warranty policies here for a better understanding.
Have a nice day!
Best Answer11-04-2020 07:43
11-04-2020 07:43
Thanks for your post.
Yes, I contacted the support team, and they were not able to solve the problem,
It is very disappointing that $150 watch stopped functioning after a year. It shows that Fitbit has a very poor quality. Support team offered me a coupon. But I decided not to buy any more Fitbit device.
I also talked to other users, most them have similar experience,
Best Answer11-04-2020 09:06
11-04-2020 09:06
Hi Deb-Paul,
What did the support team tell you to do to try and fix it? Mine has just suddenly stopped syncing and it's about 5 min slow.
Thanks!
Cheri' Powers
Best Answer11-05-2020 07:48
11-05-2020 07:48
Hello Cheri' Powers,
The support team reset my Fitbit. Also, from my phone blue tooth connections, the device was removed and reinstalled. But still it didn't work. I talked to other Fitbit users and looked into online review. These are very common problems with Fitbit and I think Fitbit doesn't have any solution.
Good luck.
Best Answer11-05-2020 09:39
11-05-2020 09:39
I have the exact same issues and mine is only 5 months old. Tried to delete the app, restart the watch reset my wifi, turned all other blue tooth devices off and everything else. Mine is now running 20 minutes slow, very disappointing. I have now cancelled my subscription because I am not paying for something that doesnt work correctly and sending it back. I will go as high as I have to and a coupon will make no difference. Cant get through to customer support either.
