Charge 3 won't sync, is there a problem as I see others with same problem . Thank you
My charge 3 won't sync,  is there a problem as I see others with same issue ,
thank you for
1 REPLY 1
Yes @Brmawi if you have restarted your tracker, then the problem is on your unknown phone.
Without this info have you looked at the help docs?
Also cleared the phones cache and stopped the Fitbit app, the shutdown the phone? Sometimes only the shutdown is needed.
