10-11-2018 19:31 - last edited on 11-17-2020 15:06 by MatthewFitbit
Charge 3 got it last night was working fine all day and I looked down at my wrist it was black so I figured it was just dead ...plug it in and it won’t vibrate turn on or show me any sign that it’s charging ?!
10-24-2018 14:47 - last edited on 02-14-2020 17:35 by LiliyaFitbit
I put mine on charge and held down the side button for ten seconds and it came back on eventually when charged over night.
10-24-2018 23:36
10-24-2018 23:36
Mine won’t even charge when I put it on charge. It’s like there’s no life in it anymore!
10-30-2018 18:46
10-30-2018 18:46
I’m having the same problem, how do I go about exchanging the product? I haven’t even had mine for a week and already having problems.
10-31-2018 04:57
10-31-2018 04:57
My charge 3 has also stopped working today, it worked fine for about 5 days. This is very disappointing.
10-31-2018 13:43
10-31-2018 13:43
Honestly, this response simply doesn't work. It's dead. No way to reset or restart what-so-ever. Stop giving people the same canned response again and again and again when you know your product is DEFECTIVE. Just admit what we all already know.
10-31-2018 14:07
10-31-2018 14:07
11-04-2018 18:13
11-04-2018 18:13
Me too Clearly a design problem.
11-07-2018 10:42
11-07-2018 10:42
Hi everyone! I'm sorry to hear about the experience that you guys have experienced with your Charge 3 since they're not taking a charge. I want to follow up on this and would like to know if you have tried the workaround that shared Marre in her post. In addition, please try charging your trackers on the other USB ports of your computers.
If the issue persists, let me know and I'll be happy to proceed accordingly!
11-09-2018 22:27
11-09-2018 22:27
Following Marre's steps for restart, things break down at #3 for me: no matter how I position the charger, no vibration or lights. Holding the "button" has no effect.
My issue is similar to others', minus the green light. I received my fitbit today, saw lights on the screen (including happy face) as I was setting up, and was able to connect to my computer and update. It was working for about 20 minutes, continuously charging. I moved to a different plug, and since have no response. The app will not connect to fitbit over bluetooth any longer, I do not have the blinking green light, no other lights or indications.
11-12-2018 04:05
11-12-2018 04:05
@em407 Thank you for joining us in this thread and our Fitbit Community! I'm sorry to hear that your Charge 3 is not turning on even though you have restarted it as recommended previously. I want to follow up on your case and would like to know if the issue persists or if your Charge 3 could get charged and turned on.
Looking forward to your response!
11-12-2018 04:39 - last edited on 02-14-2020 17:36 by LiliyaFitbit
Hi my charge works fine now I managed to shut it down and recharge it and it’s been great since. Thank you
11-12-2018 05:05
11-12-2018 05:05
@MrsB2504 I'm so glad to hear that your Charge 3 is working properly now. Thank you for posting the update here.
I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Hope to see you in our Fitbit Community!
11-12-2018 07:22
11-12-2018 07:22
11-13-2018 07:11
11-13-2018 07:11
I received mine through my Human GO365 rewards, who do I contact about it not working? It won't even respond to a charge and it is aligned properly.
11-17-2018 12:29
11-17-2018 12:29
I have my charge 3 for about a month...worked fine till yesterday, put it on went to work and noticed it was blank. Charged it and still nothing, tried to restart it, and it stays black...what do I do from here.
@Knightmare wrote:I have this exact problem. I tried plugging it in, and it won't even vibrate. The screen just stays black when it's plugged in. Tried to leave it plugged in for an hour so see if it might turn back on and all that happened was it got hot. There is no indication that it's charging at all, so I cannot reset it. I would call your support line but they're not open now.
11-18-2018 03:11
11-18-2018 03:11
My fitbit charge 3 didn’t work at all..
am in kingdom of Bahrain and its not easy to return it back..
I need a solution
11-22-2018 20:25
11-22-2018 20:25
Contact Humana Go365 you will probably have tonreturn it through them
11-28-2018 21:04
11-28-2018 21:04
I only have had my Charge 3 for three days!!!!! The stupid thing is going frowny face and I have gone through these steps numerous times and no luck. Fitbit...I am soo freaking disappointed in your product, I feel that I need to blast your rushed-to-market Charge 3 in social media until my fingers fall off. How can this thing possibly be so bad? If there is a moderator from Fitbit reading this, I want a new Charge 3 that you wear for a week and experience this issue yourself until you find one that does not do this. Then send it to me. When will you update the firmware to fix this issue once and for all. Clearly this is a major issue. Contact me ASAP and tell me how I get my new Charge 3 and also what you will do to stop me from blasting this all over social media.
11-30-2018 19:32
11-30-2018 19:32
Apparently, you really need to check twice when you charge your fitbit, that was my problem, it wasn't charged fully, once I charged it, I downloaded the firmware and it's been fine
11-30-2018 20:04
11-30-2018 20:04
I have charged mine it did go off a 2nd time around 27%. Plug it into the charge and put it on charge. While on charge press and hold the button on the side for 15 seconds. Then take it off the charge and then put it back on charge and you should get a smiley face showing it is working again. This is the worst firbit i have had.
