10-09-2018
14:14
15:47
10-09-2018
14:14
15:47
My charge 3 seems to turn on when I love my wrist. Is it possible to stop this as it wakes me up when I move at night There was this function on charge 2 and I de activated it but i can’t find how to stop this on the charge 3
If you hold down the left side “button” for a few seconds you will get two options - turn off screen wake and turn off notifications. Turning off screen wake should stop it from happening.
Sean | London, England
Charge 3, Blaze (Retired), One (Retired) / iPhone XS Max (iOS 12.2)
Please visit Fitbit Help if more help is needed
I had similar problem with my charge 3. I couldnt find the setting for quick display though, so I went through it by pressing side button, then swiping to settings->about->reboot device
that seemes to fix the problem.
Best AnswerI'm still having the problem with my Charge 3 even after rebooting. Any other suggestions?
"If you hold down the left side “button” for a few seconds you will get two options - turn off screen wake and turn off notifications. Turning off screen wake should stop it from happening or turn it on."
Thank you thank you thank you!
@seantnash wrote:If you hold down the left side “button” for a few seconds you will get two options - turn off screen wake and turn off notifications. Turning off screen wake should stop it from happening.
Best AnswerI had the opposite problem but your solution still fixed it... thank you!!
Best AnswerI've had this same problem for months & had no idea it was that simple of a fix! Thank you so much!!!! I had tried restarting it, which didn't work for me as it does for some people. I was resigned to spending the rest of my life taping my wrist to get the time (which is annoying because sometimes one hand is busy right?!). Easily seeing the time by turning your wrist is exactly why the screen wake feature exists! It's a first-world problem but still. I have no idea how this function was turned on in the first place & I'm glad to have screen wake back on! Thanks!!!
