10-09-2018
14:14
15:47
10-09-2018
14:14
15:47
My charge 3 seems to turn on when I love my wrist. Is it possible to stop this as it wakes me up when I move at night There was this function on charge 2 and I de activated it but i can’t find how to stop this on the charge 3
10-09-2018 15:27
10-09-2018 15:27
If you hold down the left side “button” for a few seconds you will get two options - turn off screen wake and turn off notifications. Turning off screen wake should stop it from happening.
Sean | London, England
Charge 3, Blaze (Retired), One (Retired) / iPhone XS Max (iOS 12.2)
Please visit Fitbit Help if more help is needed
10-09-2018 15:27
10-09-2018 15:27
10-09-2018 23:58
10-09-2018 23:58
brilliant thank you
11-15-2018 02:10
11-15-2018 02:10
I had similar problem with my charge 3. I couldnt find the setting for quick display though, so I went through it by pressing side button, then swiping to settings->about->reboot device
that seemes to fix the problem.
Best Answer11-21-2018 15:56 - edited 11-21-2018 16:16
I'm still having the problem with my Charge 3 even after rebooting. Any other suggestions?
"If you hold down the left side “button” for a few seconds you will get two options - turn off screen wake and turn off notifications. Turning off screen wake should stop it from happening or turn it on."
11-21-2018 16:14
11-21-2018 16:14
Thank you thank you thank you!
@seantnash wrote:If you hold down the left side “button” for a few seconds you will get two options - turn off screen wake and turn off notifications. Turning off screen wake should stop it from happening.
Best Answer01-11-2019 04:46
01-11-2019 04:46
Notting like that happens when I press the left button...
Best Answer01-11-2019 04:47
01-11-2019 04:47
I reloaded and now it does! Thanks!
Best Answer02-02-2019 10:21
02-02-2019 10:21
I had the opposite problem but your solution still fixed it... thank you!!
Best Answer12-11-2019 17:06
12-11-2019 17:06
I've had this same problem for months & had no idea it was that simple of a fix! Thank you so much!!!! I had tried restarting it, which didn't work for me as it does for some people. I was resigned to spending the rest of my life taping my wrist to get the time (which is annoying because sometimes one hand is busy right?!). Easily seeing the time by turning your wrist is exactly why the screen wake feature exists! It's a first-world problem but still. I have no idea how this function was turned on in the first place & I'm glad to have screen wake back on! Thanks!!!
Best Answer05-26-2020 15:52
05-26-2020 15:52
If, when holding the side button, Fitbit Pay comes up; just swipe to the left and the screen wake menu shows up.
