06-01-2021
14:51
16:06
06-01-2021
14:51
16:06
This is the 3rd Charge 4 in 2 years, something is continuously occurring at the device level where it connects to the band. The plastic on the side continues to break and the band just doesn't connect.
Not sure how to handle since this is the third one since my original purchase.
I'm not sure if I want to order another Fitbit, so disappointing.
06-03-2021 08:30
06-03-2021 08:30
Yes I purchased and this is the one that was replaced on warranty.
Its just disappointing that the product breaks occur. If it was on the band then maybe it wouldn't be as bad.
06-01-2021 19:03
06-01-2021 19:03
How tight are you wearing the Charge 4 @tialove0808?
You should be able to easily fit 1-2 fingers behind the band.
I can't think of any other reason
Best Answer06-03-2021 06:24
06-03-2021 06:24
This happened to me after 13months. They won’t replace it, I won’t be getting another one. Soo disappointed as well.
06-03-2021 08:21
06-03-2021 08:21
@SunsetRunner did you purchase an extended warranty?
Fitbit only has the obligation for 12 months. However they sometimes will give a discount on a new one.
06-03-2021 08:30
06-03-2021 08:30
06-04-2021 06:35
06-04-2021 06:35
I'm wearing it as loose as I can get it without falling off. Its on the 4th notch from the end. So its not tugging at the device connection.
Best Answer12-16-2021 06:26
12-16-2021 06:26
fibbit spokesman? it needs to be tighter than 2 fingerer or it wont be able to register heart rate etc. it should be worn loose when not working out as per manufactures recommendation and tightened when working out
this is a design flaw nothing more nothing less.
Best Answer12-16-2021 06:28
12-16-2021 06:28
they replaced mine but that one broke also think design flaw
Best Answer05-01-2022 19:37
05-01-2022 19:37
I've also had this issue 3 times already.
I love this fitbit charge 4 but there needs to be a better solution for this issue.
