09-02-2022
13:36
13:52
09-02-2022
13:36
13:52
Updated our Charge 4s yesterday. Mine still holds a GPS connection when we walk, but my wife’s continues to lose GPS after about 15 minutes
This has NEVER worked
Time to get UK consumer protection involved I think. You cannot sell people devices that do t work, and then string out the fault finding so that their warranties run out. That’s bordering on criminal behaviour
Having said that, I suspect that guarantees I’ll get zero response from FitBit
09-03-2022 05:24
09-03-2022 05:24
Hi there, @philguk. Thanks for stopping by in the Community Forums. We‘re taking your comments and sentiments in regards to our products and services into consideration.
GPS dropouts can be caused by several things (tall buildings, trees, overcast, etc.). Please take into consideration the following information when using GPS:
Make sure that you have a clear view of the sky when you start the exercise. Environmental factors, including tall buildings, dense forest, steep hills, and thick cloud cover, can interfere with your device’s ability to connect to GPS satellites. If the signal is blocked—either because you're indoors, underground, or due to another reason—GPS won't work.
For more information about GPS, see How do I use GPS on my Fitbit device?
Hope that helps.
Best Answer09-03-2022 05:37
09-03-2022 05:37
Best Answer09-04-2022 11:22
09-04-2022 11:22
I fully understand what philguk wrote, because I'm having the same issues. And all the good tips what has to be done to get a GPS connection don't help. The signal always gets lost sooner or later. It wouldn't even be so bad if at least the tracker would try to get the signal again when lost! But when it's lost, then it's lost for this session completely. I would have to start a new session while I'm still running...
09-06-2022 00:47
09-06-2022 00:47
After update latest firmware. My charge 4 cannot connect to its built-in gps AT ALL. And if it set to phone gps, it only tracked only some portion of my exercise route 😞
before update it worked perfectly.
Best Answer09-06-2022 17:00
09-06-2022 17:00
GPS on the Charge 4 is junk. It could be a clear day in the suburbs and GPS won’t connect. If it does connect then it’ll drop after 10 minutes. Fitbit’s response is ridiculous, who lives where there are no trees and it’s never cloudy.
09-06-2022 18:56
09-06-2022 18:56
I'm actually wondering if it even connects for the 10 minutes or did it not get a signal at all and it times out after 10 minutes of trying? I did a test this weekend. Went for a run, after 10 minutes it buzzed and said it had lost GPS connection. So I stopped running, ended the activity, and started a new run. I gave it about 30 seconds standing in one spot and I was on a road with no trees, obstructions, clouds etc and then started running again. 10 minutes into the activity (30 seconds standing still and 9min 30 seconds running), it buzzed at me again and said it had lost GPS connection. Did the same thing again, stopped running, ended the activity and started a new run. I gave it over a minute again with nothing anywhere around me and then started running. Guess what happened after 10 minutes again??.....Brutal! Please fix or replace with a product that works!
09-07-2022 21:36
09-07-2022 21:36
Something has gone wrong and is worse after the latest update , I am running the same route since I have this charge 4 for almost 2 years, same building around and same trees etc. it always worked even running for 21km , now within 2km it stops everyday. This is frustrating and a waste of time as your pace is messed up . This defeats the purpose of a tracker with built in GPS.
really also frustrating to see Fitbit support just copying and pasting the standard help article as a fix.
Houston we have real problem —/ Help us
09-08-2022 06:47
09-08-2022 06:47
I'm having the same trouble. Had my charge 4 for 18 months, always connects just before my daily run within a minute. Since last update won't connect.. stood waiting and waiting so end up running with it not connected. Tried hard reset (holding down the button) whilst on the charger - been for a walk again today - GPS dropped out.
something has changed.
09-08-2022 10:33
09-08-2022 10:33
Exactly! I did all the resets from the device and the 8s hold the button while charging. No change.
Last year I had an issue GPS not calculating accurately after firmware update. After much complaining and little help they eventually released some patch.
let’s see? Don’t hold your breath though 🙂
Best Answer09-08-2022 11:05
09-08-2022 11:05
Is the patch recent?
09-08-2022 19:24
09-08-2022 19:24
Best Answer09-08-2022 19:26
09-08-2022 19:26
@@Fitbit support , do you actually read these concerns and are you looking into our issue here , which is a major one??
or are we just talking to each other and hoping for the best ?
Thanks
brad
09-18-2022 19:54
09-18-2022 19:54
Hi everyone!
I'm not sure if something changed, but in the last 8 days or so I have had 4 runs that have all tracked with the GPS fine!
Here is how I got it to work:
1. Selected Excercise
2. Chose run
3. Hit Start
4. Waited about 30 seconds to 1 minutes while it says "connecting" until I felt it buzz and saw it say "connected".
5. Hit the play button and started my run
What I used to do was skip the wait on step 4 and just hit the play button. When I first got my fitbit, that worked fine and it seemed to pick up GPS while I was moving.
Not sure if this helps anyone, but worth a shot as I've had my first tracked runs in a long time actually work!
Best Answer09-19-2022 05:05
09-19-2022 05:05
I just read what Uncle Willie wrote, but I can confirm this experience. When I "prepare" my watch before the run, I let it already connect to the satellites. This is while I prepare myself for the run. So it has some minutes and probably connects to more satellites than necessary. My last three runs with 10 to 13 km worked perfectly now!
Best Answer10-03-2022 21:44 - edited 10-03-2022 21:50
Yip it’s now working , tested 5 times in a row , however , I did not do anything different from before as I always let my device connect to GPS about 5 mins before I head out. Like the previous GPS issue , it starts after a firmware update on the device. You complain to Fitbit support , they are not helpful at all, we make a noise here , then miraculously it fixes itself, strange and frustrating. At least it’s fixed.
Fitbit help now needs to apply a patch to the standard of their support :)…
Brad
