06-09-2023
22:32
11:36
06-09-2023
22:32
11:36
charge 4 GPS never connects, always need to carry my phone along.
And to top this the GPS disconnects during activity and never connects back. Sometimes I would have biked 10 miles and GPS would have disconnected around 7 and that’s the end of activity.
It is a one and half year old charge 4, will fitbit replace or repair it ?
06-10-2023 11:39
06-10-2023 11:39
Hi there, @prady32. Thanks for stopping by in the Fitbit Community Forums and sharing the details about the issue with your Charge 4.
GPS dropouts can be caused by several things (tall buildings, trees, overcast, etc.). Please take into consideration the following information when using GPS:
Make sure that you have a clear view of the sky when you start the exercise. Environmental factors, including tall buildings, dense forest, steep hills, and thick cloud cover, can interfere with your device’s ability to connect to GPS satellites. If the signal is blocked—either because you're indoors, underground, or due to another reason—GPS won't work.
For more information about GPS, see How do I use GPS on my Fitbit device?
06-13-2023 10:13
06-13-2023 10:13
Thanks but the problem I have is device doesn’t connect to built in GPS.
I have tried everything you have posted and nothing works. Anyways the steps you have mentioned are generic steps and doesn’t help.
06-27-2023 18:38
06-27-2023 18:38
Is there any real resolution to this issue? Is there any mailing address where I can send this Fitbit and your engineering can look at it ?
