11-09-2022
07:10
15:36
11-09-2022
07:10
15:36
Problem in title. Got 250 hourly steps in the 7:00 hour. Show on Charge 4, not on app or web site dashboard. This us the second time this week it hasn't synced correctly.
11-10-2022 02:53
11-10-2022 02:53
Any help?
Best Answer11-15-2022 14:07
11-15-2022 14:07
Hi there @Mayoi, it's great to see you around in the Community.
I understand how you feel about this situation. I'd recommend you check this article, Why won't my Fitbit device sync?.
Hope this helps.
Best Answer11-22-2022 10:49
11-22-2022 10:49
Hi Mayoi, I’ve had the identical issue. Today I completed 250 steps between 6-7am. Fitbit device shows I did it but the dashboard on the app does not. All the later hours synched successfully though. Weird. If I knew what I know now about Fitbit I’d seriously question buying one.
13:09
06:52
11-22-2022
13:09
06:52
Hi there @MarkPC, it's good to have you in the Community.
Thank you for sharing your experience. I'd recommend you check this article, How do Fitbit devices sync their data?.
I'll be around.
Best Answer11-22-2022 13:16
11-22-2022 13:16
LucioFitbit, nothing in the link you sent helps to explain the problems I and the other customer have reported. Do you provide these links just to say you have responded?
Best Answer11-22-2022 13:22
11-22-2022 13:22
Probably. I've had Fitbits for years, I know how to handle run of the mill sync problems. Whatever. It's working fine now.
Best Answer11-22-2022 13:27
11-22-2022 13:27
Glad its working again. Synch seems better on mine but it has still not corrected the missing active hour.
