07-24-2022
15:01
14:01
07-24-2022
15:01
14:01
There is nothing showing on the screen.
07-24-2022 19:17
07-24-2022 19:17
@Kittygrandma , a warm welcome to the Community! Thank you for your message and information.
Do the green LEDs blink?
When you sync your Charge 4, do you see the info on the Fitbit app?
Have you tried restarting it?
In the meantime, please give these tips and steps a try: Why isn't my Fitbit device's battery charging?
See you around.
07:41
17:33
JuanFitbit
07-25-2022
07:41
17:33
JuanFitbit
Hi. Thanks for reply to my questions.
The led lights on the back were flashing a few days ago, but I am assuming the Fitbit is dead now because it isn’t flashing now. I tried charging it and it wont charge. There was nothing on the screen when I realized it wasnt working. I could press the button, tap on face and nothing happened.
You said to go into Fitbit app and try restarting it by pressing about and reboot device. I do not see where it even says about.
There is account settings and app settings but neither of them have about listed.
Please let me know where to find it with my charge 4.
Thanks,
Cheryl
Sent from my iPad
Moderator edit: removed personal information
Best Answer07-25-2022 07:53
07-25-2022 07:53
I'm having the same problem. The last update screwed up my fit bit
07-25-2022 17:36
07-25-2022 17:36
@Gypsy351 , Nice to have you around . Thank you for your message.
As no information about your Charge 4 and what you have tried , please answer the following questions too:
@Kittygrandma , Thank you for your reply.
There seems to be a misunderstanding.
To restart the Charge 4 you don't need to go to the Fitbit app.
Just hold press the button of the tracker for 8 seconds.
And release it. You should then see the smiley.
If that doesn't happen, give our team a call or chat with them so that they can have a closer look at your case.
Here are our contact options.
See you around.
19:37
12:33
JuanFitbit
07-25-2022
19:37
12:33
JuanFitbit
Thank you. None of those things work. I have contacted the help desk and they could not help me either.
Thanks.
Cheryl
Sent from my iPad
Best Answer07-26-2022 12:34
07-26-2022 12:34
@Kittygrandma , Thank you for your reply and taking the time to contact Support.
If the steps provided by them did not helped, let them that know so that they can continue verifying your case.
See you around.
Best Answer07-26-2022 14:06
07-26-2022 14:06
Best Answer07-26-2022 18:40
07-26-2022 18:40
@Gypsy351 , Thank you for your reply. If the Charge 4 shows that you need to install the App , it means that your Charge 4 is no longer attached (paired ) to your Fitbit account.
Try restarting the Charge 4 and setting it up again.
How do I restart my Fitbit device?
How do I set up my Fitbit device?
See you around.
