07-27-2022
02:51
14:04
07-27-2022
02:51
14:04
My screen is hardly visible it seems to have faded
07-28-2022 03:10
07-28-2022 03:10
Mine too, yesterday. I can't tell when to press "start" etc so my GPS tracker hasn't worked.
Best Answer07-28-2022 04:23
07-28-2022 04:23
Best Answer07-28-2022 20:31
07-28-2022 20:31
I can't see any things on the display
Best Answer07-28-2022 20:56
07-28-2022 20:56
Best Answer07-28-2022 21:33
07-28-2022 21:33
The sleep mode is turned off already
Best Answer07-28-2022 22:19
07-28-2022 22:19
There's a brightness setting. You may have accidentally set it to dim.
With the display on swipe left twice and look for 'Settings'. Tap it and Brightness will be the first one displayed at the top. Tap it to cycle through the three options: Auto, Normal, and Dim
Hope that helps.
07-29-2022 02:47
07-29-2022 02:47
it is in Norman but screen is hardly visible
Best Answer07-29-2022 06:15
07-29-2022 06:15
Verify that Sleep Mode is not on.
Best Answer07-29-2022 07:44
07-29-2022 07:44
Thank you. That helped!!
07-30-2022 00:46
07-30-2022 00:46
Best Answer07-30-2022 00:47
07-30-2022 00:47
07-30-2022 00:48
07-30-2022 00:48
