05-24-2020 12:43 - last edited on 12-14-2022 16:20 by MatthewFitbit
I can’t see my Fitbit screen if I’m outside
09-18-2021 00:53
09-18-2021 00:53
Me too not good in sunlight at all..went swimming yeti outdoors impossible to check training time without actually stopping which is not good. I had an apple watch before this (also had its problems and waaay overpriced) ans you could check stats at a quick glance in bright sunlight
12-23-2021 13:19
12-23-2021 13:19
Thanks for the tip! It was in sleep mode!
02-18-2022 17:28
02-18-2022 17:28
I was having the same problem. I’ve attached a screenshot of the answer.
Nancy
02-18-2022 18:40
02-18-2022 18:40
Thank you. I did find it in the end. I’d somehow turned the screen down.
05-15-2022 18:34
05-15-2022 18:34
08-26-2022 22:10
08-26-2022 22:10
I only have auto and normal brightness to select from. Fitbit is unusable outside.
11-03-2022 16:58
11-03-2022 16:58
Thanks Nic, I'm hoping that will stop it from going to "Dim."
11-05-2022 18:49
11-05-2022 18:49
It’s horrible… my eyes are already bad enough.
