05-04-2023
21:10
07:07
05-04-2023
21:10
07:07
I have a charge4. I noticed tonight it cleared my steps. It was on my device and on my app then it wasn't and I noticed it cleared the last 3 days. It shows calories burned but no steps. I turned my device off and back on. I changed the clock face. I looked for Mobil tracker and I can't find it. My steps were there during the day then they are gone. Any other suggestions?
05-06-2023 02:24
05-06-2023 02:24
Hi, @surf1978 , did you happen to log out of your app and log back on again? I would confirm that you logged on with the same email and password that you use with your Fitbit account.
Best Answer05-09-2023 01:36
05-09-2023 01:36
This usually happens when the battery of your buddy is too low. I'd like to know if at any moment your tracker turned off . To avoid this in the future, I recommend making sure your Flex has enough power. To recover the steps lost, manually log your activity is always a good option.
Regards
Diana
