04-10-2023
23:27
10:04
AndreaFitbit
04-10-2023
23:27
10:04
AndreaFitbit
My charge 4 stopped syncing four days ago. I have had this problem before and all I did was unpaired and re-paired. This time it won't pair back to my phone. My phone finds the device through my Bluetooth but can't/won't go any further then that.
Moderator edit: format and label.
04-11-2023 10:13 - edited 05-26-2023 12:54
Hi there, @LunaL219. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Charge 4 before reaching out.
In addition to the steps you've done, please try the following in the order listed:
With the steps above, what I want you to do is to pair your Charge 4 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Best Answer04-11-2023 10:13 - edited 05-26-2023 12:54
Best Answer04-11-2023 22:03
04-11-2023 22:03
So I did all of that. I now get to the code part and then I get stuck.
Best Answer04-11-2023 22:11
04-11-2023 22:11
On your phone, go to Settings. Bluetooth and turn Bluetooth off and back on. Open the Fitbit app and try to sync your device. If your device doesn't sync, restart it.
Best Answer04-13-2023 15:59
04-13-2023 15:59
I am having the same issue with two of my Charge 4’s. I did all the same troubleshooting above but both only get as far as putting in the code and then nothing happens.
Best Answer05-04-2023 01:38
05-04-2023 01:38
Fitbit sync errors are usually related to the fitness tracker becoming disassociated with the smartphone, tablet, computer, or iPod touch it was initially connected to. This can be caused by connecting to too many devices at once, the Bluetooth not working properly, or a minor glitch in the Fitbit's operating system
Regards,
Diana
