03-14-2023
21:35
04:47
DavideFitbit
03-14-2023
21:35
04:47
DavideFitbit
I am unable to sync my Charge 4 to the application since last week. I tried to remove the device from app and pair it again with a hope that it might work but now I am even unable to pair my watch. Please assist
Moderator edit: format
03-15-2023
10:19
04:51
DavideFitbit
03-15-2023
10:19
04:51
DavideFitbit
I also couldn’t get my charge 4 to sync. Uninstalled it and tried to reinstall it. It connects to my phone and I get the 4 digit code to enter on the app. After I enter it it tries to install but can’t and the is a message scrolling across the bottom of the charge 4 screen that tells me to download the Fitbit app or update it. I am already using the app to install the Fitbit and I updated it and still get the same thing every time. Come on fitbit! Figure out a fix for this. I can still use it as a watch but since I can’t reinstall it and sync it the time is almost a minute behind which is what started this whole issue. I noticed that the time was off and tried to sync it with the app so that the time would adjust and now I have a Fitbit that only tells me the time and isn’t accurate at that. These things are to expensive to just stop working for no reason.
An update to my previous post. About an hour after I tried to re install my charge 4 one last time, I felt a vibration on my wrist and looked down to see a green check mark on the screen. I opened that app and everything was back to normal and working. I can’t explain it. I didn’t do anything different but it finally worked. Good luck to everyone else with this issue.
Troubleshooting tips
Force quit the Fitbit app on your phone.
On your phone, go to Settings.
Open the Fitbit app and try to sync your watch.
Regards,
Rachel Gomez
Best AnswerFor me, it's still the same 😞
08:48
09:16
03-17-2023
08:48
09:16
Hi, welcome back to the Community forums, @AdityaSingh.
I appreciate all the information that you've shared about the difficulty you're experiencing with your Charge 4.
If you're having trouble to pair your device, please follow the recommendations in this article. If the device is paired and you're not able to sync, please try the following steps that have been useful for other users:
In addition, I recommend that you try restarting the device. If you're still having any issues, let me know if you already tried all the steps listed here to resolve syncing problems, and make sure to check the compatibility requirements listed here and to keep the Fitbit app updated to the latest version available.
@UnhappyinAlg @RachelGomez1619 Thanks for taking the time to share the steps that worked for you.
01:03
09:50
DavideFitbit
03-20-2023
01:03
09:50
DavideFitbit
I am having the same problem as everyone else. Since the 10th of March I haven’t been able to sync. What you have suggested still does not work.
And Davidefitbit what do you mean the flat end, have you seen the Charge 4 charging cable? It has a gripper, no flat bit.
09:24
09:01
03-29-2023
09:24
09:01
@Kiwifire Thanks for your reply.
Could you please provide a few more details about the issue you're experiencing and about the steps that you already tried that were not successful? Is your device not syncing at all or it does sync at times? Are you able to see any information in the app?
Thanks for the feedback about the restart procedure, I've updated my post with the correct information.
Best AnswerHello Davide,
I tried to reset my Charge 4 and did the steps you mentioned above.
My issue started when I bought a new phone, a Samsung S22. The fitbit app and phone have the most up-to-date versions.
To me, it seems there is a bug or something since several people have been having issues.
Thanks for your help,
Erin
07:03
08:54
04-03-2023
07:03
08:54
@UnhappyinAlg @Usirishgirl Thank you for your reply and for confirming that you already tried all the steps suggested earlier.
In this case, since you already tried the steps suggested earlier, I recommend that you get in touch with the Customer Support team for further assistance with this. They will let you know how to proceed.
The best way to get help for this problem is to chat with us online or give us a call. You can click here to get connected.
11:22
06:10
DavideFitbit
04-03-2023
11:22
06:10
DavideFitbit
I'm having the same problem since last Thursday. It's stuck on 3,118 steps and nothing is updating--sleep, steps, etc. So frustrating. I've deleted the app and reinstalled, logged off and then back on, and force quit and restarted. C'mon, FitBit--fix this, please!!
06:09
08:47
04-05-2023
06:09
08:47
Best AnswerHi David, I just restarted the tracker itself (missed that one instruction) and it appears to be working again because my steps zeroed out but starting counting as soon as I put it on and walked around. I'll return and let you know if it's still having problems, but I do think it's fixed. Thank you!!!
06:33
08:00
