10-28-2022
		01:37
		13:05
		10-28-2022
		01:37
		13:05
I had a Versa 3 with the same problem and bought versa 4 june 2021 and now I already have the same problem.
I already used another cable from someone but this does not help, so it is not the cable ; the fitbit does not start to charge, neither displays anything else when connected (even not the smiley). I'm love my fitbit but i am not happy with the same problem in 1 à 2 years. If i cannot solve it this time I wil buy another type of tracker this time.
10-28-2022 03:50 - edited 03-06-2024 04:52
 Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
Hi there, @Vyvey. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Charge 4 and trying another charging cable already.
Probably is not the charger, but the Charge 4 having some trouble to be charged. So, with that being said, please follow all tips and recommendations provided in this help article Why isn't my Fitbit device's battery charging?
I've moved your post to the Charge 4 board for organization purposes.
Hope that helps.
Was my post helpful? Give it a thumbs up to show your appreciation!  Of course, if this was the answer you were looking for, don't forget to make it the Best Answer! Als...
Hope that helps.
11-02-2022 01:47
11-02-2022 01:47
Thanks, it's working again.
11-02-2022 08:03 - edited 11-02-2022 08:03
Vyvey, yeah! what did you have to do?
Barbara
 Best Answer02-25-2023 02:31 - edited 02-28-2023 01:40
iam also facing the same issue.I found some fixes online regarding fitbit charge 4 not turning on. It's working now
this is what I did: I made sure I charged it to full and then after some time did a hard press to restart.
02-25-2023 10:47
02-25-2023 10:47
It worked for a while but now a few months later i have again the same issue, not charging anymore..
no solution yet
 Best Answer02-25-2023 10:48
02-25-2023 10:48
I don’t have a solution, again the same issue here as well
