Charge 4 won't turn on
Hi,
I got the charge 4 today! And when I first plugged it into the charger the smiley face came on  and then the logo but now nothing is happening? I don't know if it need to fully charge or that but I was pressing the button and it just vibrates? Any help is appreciated!
38 REPLIES 38
Hello there @Vicky20, welcome to the Community Forums. We're sorry for the late response, due to recent events affecting our operations, we're taking longer to respond. Thanks for the details about your Charge 4's behavior, we're here to help.
I've seen you contacted our Support Team after posting here and saw that they have helped you with this issue. 😉
I've moved your post to the Charge 4 board to get more chances of visibility to others.
We'll be around if there's anything else we may do to assist you.
Hi Vicky, this happened to me too. How did you resolve it?
If you have seen the smiley face, then your tracker has turned on.
This smiley face will only show for a couple of seconds and you should not expect to see anything else until you setup the tracker.
My thought would be to open the Fitbit app up and setup the tracker.
How was this solved?
Yeah I got sorted thank god! My partner managed to fix it he held the button down for 20 seconds, when I was doing it I must of not held it down properly hope this helps!
Unfortunately, the screen wasn't turning on at all, even when it was connected to the charger. I found a solution though deep in some other forum.
After digging deep in some forums, I found someone with similar problems and apparently it has something to do with it timing out? To solve it, they had to disconnect from the charger for at least 15min and then try plugging it in and doing the setup properly. I did that and it is now working again.
Hey guys, I hope you are doing fine.
I am sorry for the delay in response, due to recent events affecting our operations, support options are limited and wait times are longer than usual.
@Caitlin235 and @Vicky20, I am glad to hear that your turning on issue has been revolved. If there is anything else we can help you with, do not hesitate to post it.
@Earl27, I would like to know if you keep having this problem? Have the steps provided by our friends worked?.
@Rich_Laue, thanks for the input.
I will catch you later. 🙂
just got my 4 yesterday, doens't work, button won't even push in to turn on.  Fully charged, smiley face intially came on, but now won't do anything. only get error codes when I log on to set it up.  Guess I'll have to return
This happened to me! Screen is totally blank but my app is showing that it’s fully charged.
Returning today
I called customer service, only waited for about 2 minutes on hold, and they talked me thru (basically undoing setup, starting from scratch, and redoing it) and it’s good to go! In less than 15 minutes. For some reason the setup didn’t complete last night but it did today. Super friendly tech support! So happy I don’t have to return.
Hey guys, thanks for your participation in the Forums.
I appreciate all the efforts in trying to fix this display issue. @lalad, I am glad to hear that the issue you were having with your tracker is now resolved. If there is anything else we can help you with, do not hesitate to post it.
And @doonsey, I am sorry to hear that you returned the device. If in the future there is anything we can help you with, let us know.
Happy stepping! 😉
Hope your fix will work for me. Please tell me what it is! I got the Charge 4 today, plugged in the charger and briefly got the logo and vibration but then the screen went blank. Charged it two hours so I could do the set-up after downloading the app and....nothing. Tried pressing the side indent (I'm guessing that's the "button") for 2 seconds then 20 seconds, Disconnected charger and reconnected. Took FitBit off the charger.  Back on the çharger. Plugged in charger. And -  nothing on the Fitbit. Screen stays blank.  Can't set-up. Can't connect to anything. I'm at a loss. Help!
What many people don't realize is that the button is inductive. Meaning it is not a physical button you can press down on. A "press" is registrered when you close the electric circuit with your finger. I.e. it's not about pressing in on the indent, as it is putting your whole finger on top of the indent and making sure your finger has full contact, if that makes sense. That was what worked for me anyway. Also, it is more like 20 seconds to turn it on/off, rather than 10 seconds.
I sent back they have had since July 6th and I can’t get any response from
them and no money back. I am not happy
i tried 20, 30. 40. 60 seconds, still didn't work, i got two vibration in the beginning
my problem solved, unplugged from charging for 30 minutes and try to reconnect
Hi Caitlin
I got the same trouble with my charge 4.
Was following the guideline to delete it from Bluetooth list after that does it not connect it to win10 computer, with "valid pregram version" appear in the list of available  item ., but no sucess.
The unit shows like for you only happy smile after 10 sec, the is fitbit logo with txt www.fitbit.com/setup shown.
thanks in advance
Miikke
