02-15-2017
10:00
20:15
02-15-2017
10:00
20:15
Hello,
Does anyone have any solutions on replacing the loop/keeper on the strap that holds the extra length of the band in place? The loop on my wife's band broke off, and the unit was purchased in 2015 so no warranty left. I have already contacted support, but they were unable to resolve the issue by sending me a replacement loop. They said that it wasn't a part that they replace.
Thanks for your input....
02-15-2017 13:05
02-15-2017 13:05
You could get some Bitbelts
Also an O ring from any hardware store works as well
Wendy | CA | Moto G6 Android
02-15-2017 13:05
02-15-2017 13:05
02-15-2017 13:13
02-15-2017 13:13
Hey WendyB,
Thanks for the suggestion. I was thinking about picking something up from the hardware store but really didn't want to go that route, I like the other solution better from Amazon.
Thanks for taking the time to respond!
06-23-2019 09:52
06-23-2019 09:52
Did it work? I have the same problem, broken Charge HR loop.
01-04-2021 01:26
01-04-2021 01:26
I have same problem. Fitbit falls off arm especially of a night time. Kind of renders it a bit useless. Absolutely poor they don't have replacements. I'll try the O ring from hardware store, tried a rubber band but that just cut into me. Unimpressed with their service for a watch that cost $$$ and looks pretty crap with rubber band holding it on.
01-23-2021 08:27
01-23-2021 08:27
01-23-2021 13:16
01-23-2021 13:16
04-27-2021 09:06
04-27-2021 09:06
how do you know what size Bitbell replacement to buy (I have inspire hr) thank you
