08-24-2017
03:51
20:15
08-24-2017
03:51
20:15
I have had my fitbit since February 2017 and I go and charge it last night wake up this morning and there is no display screen stuff a reset on it still no display screen. Please help really need to get this fixed.
08-24-2017 18:25
08-24-2017 18:25
Thanks @King1031! I hope this helps you too @gleng!
I had the exact same problem with my old Charge HR in the past. Everything worked perfectly except for the screen. So I opened up a chat with the Fitbit support team and they gave me replacement. So what you are probably experiencing is a hardware issue. I would highly suggest opening a Chat with Fitbit support!
I hope this helps!
Michael Groff | CO, USA
Fitness isn’t being better than someone else, it’s being better than you used to be!
Best Answer08-24-2017 06:40
08-24-2017 06:40
Hi @King1031! Welcome to the community! Are you certian that your Charge HR took a charge?
Best Answer08-24-2017 14:56
08-24-2017 14:56
Yes the green lights are flashing and my dashboard said full charge.
Best Answer08-24-2017 16:52
08-24-2017 16:52
I have the same problem. Its charging and otherwise works but there is no display.
Best Answer08-24-2017 18:25
08-24-2017 18:25
I hope this helps!
Best Answer08-25-2017 05:01
08-25-2017 05:01
I just called customer support and they replaced mine
Best Answer08-25-2017 09:43
08-25-2017 09:43
Glad to hear that @King1031!
Best Answer05-06-2019 00:01
05-06-2019 00:01
I am not happy with my Fitbit Aspire HR. I've only had this for maybe a month and the screen has gone blank. I've tried every suggestion on the web. I never had any problems with my Garmin Vivofit for 3 years! I want my $100 back.
Best Answer05-06-2019 12:59
05-06-2019 12:59
