11-04-2018
13:47
15:03
11-04-2018
13:47
15:03
Hello- having real trouble charging my battery! The Fitbit vibrates when it’s connected to my computer but I never get the battery icon and it won’t charge. Any help would be greatly appreciated!
11-04-2018 14:07
11-04-2018 14:07
If you've opened them wide enough then the bottom of the clips should be touching the main body of the charger.
Two other things to check:
1) Are you putting the Charge 3 in the right way round in the charger? The little dent in the left hand side of the Charge 3 should be in line with the hole that's on one of the clips of the charger.
2) Try another plug socket / USB socket / USB plug to see if that makes a difference. Something to note is that Fitbit say not to use a USB hub for charging. This is because many don't provide enough power for charging.
Sean | London, England
Charge 3, Blaze (Retired), One (Retired) / iPhone XS Max (iOS 12.2)
Please visit Fitbit Help if more help is needed
Best Answer11-04-2018 13:57
11-04-2018 13:57
I had this exact problem. I discovered I wasn't opening the "clips" of the charger wide enough when putting my Charge 3 in. So, even though it fitted in and vibrated, it didn't make that final contact with the charging points and so didn't charge.
11-04-2018 14:01
11-04-2018 14:01
11-04-2018 14:07
11-04-2018 14:07
Best Answer11-04-2018 14:15
11-04-2018 14:15
11-04-2018 14:17
11-04-2018 14:17
Phew! Glad it was something so easy to remedy 😄
Best Answer11-05-2018 05:49 - edited 11-05-2018 05:49
It's nice to have a new member, welcome @Jennyeli! I'm glad to hear that your Charge 3 is charging now after testing with another USB port.
In case you or anyone else who jumps in here asking for the same need it, please see: Why isn't my battery charging?
I made @seantnash's post as the solution for your previous post. Highlighting the solution may be discovered more easily by other community member's facing the same questions or issues as you. You can read more about Accepted Solutions here.
I'll be around if you need further assistance!
Best Answer11-05-2018 08:36
11-05-2018 08:36
I tired another port and another charger, my fitbit remains at 10% and will not charge further. This is one of many issues with this model.
11-05-2018 08:53 - edited 03-01-2024 03:36
Thanks for jumping in here @EmpressVashti! Also, thanks for already trying a different USB port.
I'd recommend restarting your Charge, from the clock face, swipe to Settings and tap Reboot Device.
You can also manually restart it by following these steps:
Once you've done that, please check and review the tips and recommendations in the article: Why isn't my battery charging? There are some factors prevent your Charge 3 from getting charged.
11-05-2018 08:58
11-05-2018 08:58
Just to note @EmpressVashti and @MarreFitbit that only those with the 1.44.33 firmware have the option to reboot their device from the Charge 3 menu. Everybody else can only reboot using the charger method.
Best Answer11-05-2018 09:05
11-05-2018 09:05
Yup @seantnash, thanks a lot for adding that to my response. You rock! ![]()
03-16-2019 16:43
03-16-2019 16:43
Thank you!!!!! Solved my problem.
Best Answer02-14-2020 09:02
02-14-2020 09:02
Found this very helpful! Thanks. Tried all that you said and now it is charging. Oh Happy Day!
Best Answer04-06-2020 00:17
04-06-2020 00:17
Hi my Fitbit won’t charge. The Fitbit charge screen displays 1% and doesn’t change after charging for more than 30mins. I have changed the USB port, cleaned the pins. I have also reset the device but these actions have not resolved the issue. I wore it in the shower this week which I don’t normally do. Could this have affected the battery? My watch was purchased in October 2018 so I don’t think the warranty is valid now. Any advice please?
06-17-2020 19:48
06-17-2020 19:48
I got exact same issue and can’t charge also become quite hot looks like it is going to burn
Best Answer06-18-2020 01:24
06-18-2020 01:24
Charge 3 less than 12 months old now needs charging every 20 hours any ideas
Best Answer06-18-2020 19:41
06-18-2020 19:41
Best Answer02-25-2021 08:07
02-25-2021 08:07
Best Answer07-15-2021 19:53
07-15-2021 19:53
Looks like this restarted my tracker and it is charging! Thanks
07-16-2021
04:46
03:53
07-16-2021
04:46
03:53
Hello everyone. @dixiechic2592at Welcome to the community forums!
I'm glad to hear that the instructions that were shared in this thread helped. I hope you can continue tracking towards your fitness goals.
On a side note, I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
See you around.
