02-15-2017
15:12
10:13
02-15-2017
15:12
10:13
I have had the Charge2 since October. Everything was working fine until now. I just realized it is not tracking ANY floors since Sunday. I live on a third floor and take the stairs whenever I can. What can I do about this?No track record of steps
02-28-2017 09:25
02-28-2017 09:25
@pobeeche Since you have already tried the suggested troubleshoots I think it is time to contact our Support Team for further assistance. They are able to review your tracker's information and provide assistance and options for your case and guide you through the process. You can also review the warranty page if you have any questions.
I'll be around!
Best Answer02-15-2017 15:30
02-15-2017 15:30
@pobeeche, check the small altimeter hole on the back of the tracker that is used to detect changes in atmospheric pressure, to make sure it is not plugged and unable to measure pressure changes. The small hole is on the back of the tracker, on the top edge. If it has become plugged with lint or dirt, it will not be able to measure the changes in height.
02-16-2017 07:03
02-16-2017 07:03
@pobeeche Thanks for stopping by! @USAF-Larry is right that if the altimeter is blocked then your tracker won't be able to detect the variances in atmospheric pressure so it won't detect your climbed floors. You can use compressed air at a distance to clear this area and you can also try restarting your tracker by doing the following:
Plug the charging cable to your computer or UL certified wall adapter.
Align the contacts of the tracker with the charging cable and plug it in making sure it snaps securely.
Your tracker should start charging.
Press the button for 10 to 12 seconds.
You should see your tracker's firmware version and you can now unplug your tracker.
Let me know how it goes!
02-17-2017 08:37
02-17-2017 08:37
Thanks Larry it seems like it wasn't plugged I will try reseting it now to see if it changes
Best Answer02-17-2017 11:48
02-17-2017 11:48
So it wasn't clogged but I cleaned it anyway. I did the restart and it's still not working. Any other suggestions? How does the return policy work?
Best Answer02-28-2017 09:25
02-28-2017 09:25
I'll be around!
Best Answer03-25-2017 10:30
03-25-2017 10:30
BTW... now it's over counting floors, I had gone up 6 flights of stairs all together today, I have a count of 179... it's been happening for a while 300+ the other day too
Best Answer03-31-2017 22:06
03-31-2017 22:06
I had this problem too. I tried everything suggested by this Community but the problem solved itself when I accidentally let the battery run completely flat. I recharged and restarted my Charge 2 and it started counting floors again! That was some weeks ago and I've had no other problems since then.
08-03-2018 09:36
08-03-2018 09:36
Thanks, that’s exactly what was wrong with my Fitbit. A lot of crud in that little hole, but I’ve had this unit for 2-3 years. I do a lot of stairs as well and for 8 weeks it’s said no stairs. Got support online on the web and they basically said to reset the watch. That didn’t work, but this sure did. Thx again.
08-19-2018 09:58
08-19-2018 09:58
@jeboza It's great to see that you've visited the Fitbit Community! Sorry to hear that your Charge 2 wasn't counting stairs and for the delay in my reply. Thank you so much for trying my suggestions and for sharing your experience in the Community. The fact that it worked for you may encourage other members to try the suggestions and possible solve the issue. Hope you reach your fitness goals in not time.
I'll be around!
Best Answer10-14-2019 12:31
10-14-2019 12:31
Disappointing! Nothing I've tried works (all the recommended fixes), and I'm climbing these days - no elevation is being tracked. IMHO, an expensive unit like this should perform better. Mine is quite new.
Best Answer10-14-2019 13:05
10-14-2019 13:05
Best Answer04-11-2020 18:16
04-11-2020 18:16
I don't see a hole on my Fitbit and my steps have not worked in forever
Best Answer04-11-2020 18:17
04-11-2020 18:17
That was in response to people saying that there was an altimeter hole that might be plugged that would keep the steps from counting?
