04-18-2020
06:20
09:49
04-18-2020
06:20
09:49
I’ve had my Charger 2 several years now. I have noticed in the last month or so it has “false” charge. Last night I charged it and it show full charge, but I could tell is was the “falsely“ charged, so I left it charging. This morning it’s dead. Lights on back are only one(lower) and very dim; top light dead. I can’t even restart it. Must be burnt out? Help anyone....
04-27-2020
11:17
08:13
04-27-2020
11:17
08:13
@FBrunner5 I hope you're doing well! Sorry for the delay in my reply.
Let me help you with your Charge 2 not charging properly. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves. You can follow these instructions to help your tracker charge.
Let me know how it goes.
Best Answer04-28-2020 03:48
04-28-2020 03:48
