09-21-2020
09:39
13:34
09-21-2020
09:39
13:34
What is the best way to clean the actual tracker on the Charge 3? There is build up where the band meets the tracker.
Hi @Atlhockeylove the basic care is listed here - click to read. What I've done with all my Fitbit devices is use a toothbrush with rubbing alcohol. If you need to dig in a bit, a toothbrush works great.
Best AnswerThank you so much. I was concerned using a toothbrush would harm the electronic parts. 🙂
