01-03-2018
00:37
18:54
01-03-2018
00:37
18:54
How do I stop or reduce the feed posts from the community, I get way too many and it fills my screen on phone, I have checked my notification settings but cannot find an answer?
There are a few ways to stop or keep these from even starting.
When you make a post, before hitting submit, uncheck the "email me when someone replays".
To change this default, tap on your picture, then tap settings. From here you can set your default to not subscribe.
At the top of the page there is a button called "options", under this there will be a unsubscribe.
Tap on your picture in the top right, then tap subscriptions. From here you can unsubscribe.
@SunsetRunner If you are referring to the notifications about reaching your step goal or a new auto recognized activity, then do the following. Go to you web dashboard at fitbit.com. Click on the Gear (Settings) icon in the upper right. Click on Settings, then on Notification in the left side list. Uncheck any and all of the Mobile Notification you wish to stop getting.
This won't get rid of the ones that are already there, but there is a Feature Suggestion asking for the ability to remove these notifications. It is in the Reviewed by Moderator stage, so maybe help is coming.
Laurie | Maryland
Best AnswerHi how do I edit or stop the numerous notifications from community clogging up my screen. I love the community side of Fitbit but hate the constant notifications popping up alerting me that so and so has also replied to a post I replied to. Because I can’t figure out how to minimise this I have ended all my groups instead just to get some peace from the constant notifications.
Any advice greatly appreciated thanks.
I am referring to the notifications from the community arena and NOT my personal goals.
Best AnswerHello,
I had the same issue and tried all sorts of methods to stop the barrage of notifications, the only way I found that worked was to do as you have said, leave all the groups, which is a shame.
Good luck with your Fitbit adventure 🙂
Best AnswerThere are a few ways to stop or keep these from even starting.
Best AnswerHi there , l had the same problem and so l left the groups , had quite a few and was told they dissapear 30 days after they are posted and they have , but not sure if the same applies from friends l will just wait and see , l liked the groups but l was getting to many so that is why l left 😣
I took your advice regarding turning off notifications! I hope it works. It's insane that there would be no way to those annoying notifications.
Best AnswerAre we asking about the notifications that appear on the Charter 2, or are we asking about the community notifications found in the unrelated topic of the fitbit app?
Thanks for the screen shot. It helped me figure out I have to be on a PC to see what you are talking about. These on not visible on the mobile version of the site.
cori
