02-03-2021
22:48
03:28
JuanJoFitbit
02-03-2021
22:48
03:28
JuanJoFitbit
I've recently moved country and my fitbit will not show the correct time. Oddly it's not correct for my previous country either. I have rebooted, repaired, synced the device a number of times as well as manually changing the time zone but I cannot get the device's time to change. Can anyone help?
02-04-2021 03:27
02-04-2021 03:27
Hi @Trixypie, welcome to our Fitbit Community. Regarding the time zone and clock issue that your Charge 3 has experienced, I appreciate the time spent trying to get it resolved before contacting our forums.
I'd like to know if you have restarted your Charge 3 as described in this help article. Also, let me know if your phone has the current time-zone.
In the meantime, make sure that your phone runs the most recent Fitbit app version.
Looking forward to your response.
Best Answer02-05-2021 23:03
02-05-2021 23:03
Thank you for replying. Yes, I found that post before I asked my question - I had no success. At some point in the night my fitbit corrected itself, however it has now reverted to the wrong time again. Do you have any other advice for what could be wrong?
Best Answer02-08-2021 08:00
02-08-2021 08:00
Hi @Trixypie, thank you for trying the steps previously shared. I'd like you to try one more workaround, which has been helpful for this type of issues. Please try a factory reset. To do so on your device, follow the steps below:
After this, set up your tracker from scratch on your existing account and see if the issue gets fixed.
Keep me posted on the outcome.
