04-04-2018
09:43
20:15
04-04-2018
09:43
20:15
If I know my BMR more accurately through metabolic testing, is there a way to customize it?
04-04-2018 23:49
04-04-2018 23:49
There's no direct way to set your BMR. The best you can do is to tweak your profile settings for age, height, weight until it comes up with the numbers you want.
Best Answer02-20-2019 12:05
02-20-2019 12:05
does customizing height (had to go from 165cm to 100cm to match my true BMR lol) affect calorie burn rate while exercising or other functions ? thank you. ![]()
Best Answer02-20-2019 12:43
02-20-2019 12:43
I believe it will be affected in the same way as BMR calories but I have not seen documentation from fitbit that confirms this.
