06-06-2020
04:59
02:17
EstuardoFitbit
06-06-2020
04:59
02:17
EstuardoFitbit
All of the sudden it started acting up yesterday, it switches between functions by itself without me pressing the button. After a while it stopped shifting between functions and worked normally but the battery was draining and I charged it the it was ok. Today, the battery was draining until the device stopped working totally. I connected the charger but it is not coming back to life, please what should I do now. Obviously it needs a professional checkup!!
06-11-2020
09:56
06:56
06-11-2020
09:56
06:56
@Abdul1st Thanks for being part of our Community!
Let me help you with your unresponsive Charge 2. Not sure if this a battery issue or a screen issue so I suggest you try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves.You can follow these instructions to help your tracker charge.
Let me know how it goes.
