06-04-2018
15:05
18:54
06-04-2018
15:05
18:54
A couple of weeks ago, I noticed a line of dead pixels across the display of my Charge 2. Since then, more and more lines of dead pixels have cropped up, in addition to the Charge 2 no longer holding a charge for more than about a day and a half. I've implemented some of the strategies to increase battery life already, so we'll see how that goes, but nothing has been able to fix the dead pixels. I'm worried eventually the entire display will go black. Anyone had any luck restoring their display?
06-04-2018 15:11
06-04-2018 15:11
Have you tried a Restart? Do it several times if necessary.
Best Answer06-04-2018 16:31
06-04-2018 16:31
I have tried restarting it a couple times (plus a couple complete battery drains due to the battery issue mentioned previously) and I'm still seeing lines of dead pixels.
Best Answer06-04-2018 16:38
06-04-2018 16:38
Contact Customer Support.
Best Answer06-23-2018 12:45
06-23-2018 12:45
My Fitbit has done the same in the last week, I’ve tried the multiple restarts but they are getting worse with more lines going
Best Answer08-27-2019 12:11
08-27-2019 12:11
My charge2 is doing the same it's had horizontal lines across the top for about a month now I have wider vertical lines. In sunlight you can't see anything on the screen despite it being set at normal !! I have tried battery drains, several restarts using watch and several restarts using the charging cradle,but nothing has worked 😟🤔
Best Answer08-31-2019 07:33
08-31-2019 07:33
I ended up needing to contact Customer Support and get my Charge 2 replaced. Best of luck with your Charge 2!
