03-01-2019
02:53
17:14
03-01-2019
02:53
17:14
Hi,
I use the tracker on my app for my morning walks. I select 'walk' from the tracker screen but the app always seems to record them as runs, which I am unable to change manually - I believe there is a default setting somewhere which I need to change?
It's not a big problem, but it would be nice to see my walks recorded as walks. All the statistics are fine, though, it's just the name of the exercise.
Thanks
03-01-2019 02:56
03-01-2019 02:56
Are you using the android app? If so, then you are probably being affected by an ongoing bug which is causing this and which fitbit are investigating.
Keep an eye on the following thread which has their updates on progress:
03-01-2019 02:56
03-01-2019 02:56
03-01-2019 03:21
03-01-2019 03:21
