Display charge 3
ANSWERED
How can i adjust the brightnes of my charge 3. It is in normal mode when i change to auto i cannot read it at all
1 BEST ANSWER
Accepted Solutions
@Steensel Unfortunately, "max" is not an option on the Charge 3.  The "normal" setting is the highest the brightness will go with the Charge 3.
Heather | Community Council | Eastern Shore, AL
6 REPLIES 6
The brightness setting you have been using is the only way to adjust brightness.  Have you tried the Max setting?  That's what I use.
Hello cbwilsha
Can you tell me how to set max Intensity
It does not show in my setting menu
Verstuurd vanaf mijn iPhone
At the brightness setting I referenced, you can toggle thru Dim, Normal, and Max by tapping on the setting.
Thank you very much, Heather, for the correction.  I had checked the User Manual but it wasn't specific so I was assuming same as Versa.
@SunsetRunner No worries!  I wish we did have a "max" setting for the Charge 3!
