04-11-2020 11:52 - last edited on 09-17-2020 15:30 by
How can i adjust the brightnes of my charge 3. It is in normal mode when i change to auto i cannot read it at all
04-12-2020 06:15
04-12-2020 06:15
@Steensel Unfortunately, "max" is not an option on the Charge 3. The "normal" setting is the highest the brightness will go with the Charge 3.
Best Answer04-11-2020 16:52
04-11-2020 16:52
The brightness setting you have been using is the only way to adjust brightness. Have you tried the Max setting? That's what I use.
Best Answer04-12-2020 00:04
04-12-2020 00:04
Best Answer04-12-2020 06:09
04-12-2020 06:09
At the brightness setting I referenced, you can toggle thru Dim, Normal, and Max by tapping on the setting.
Best Answer04-12-2020 06:15
04-12-2020 06:15
Best Answer04-12-2020 06:28
04-12-2020 06:28
Thank you very much, Heather, for the correction. I had checked the User Manual but it wasn't specific so I was assuming same as Versa.
04-12-2020 10:41
04-12-2020 10:41
@SunsetRunner No worries! I wish we did have a "max" setting for the Charge 3!
