08-05-2019
16:52
10:55
08-05-2019
16:52
10:55
I can’t read the display. It’s too dark? I can’t find a location to change the background or the display.
11-04-2020 05:38 - edited 11-04-2020 05:39
06-18-2021 03:09
06-18-2021 03:09
I couldn't find the display control on my settings. Help?
06-22-2021 06:58
06-22-2021 06:58
Hi, thank you for your inquiry @tracibiker.
Could you please provide a few extra details? Let me know if you're trying to find the display settings to adjust the brightness or if you're trying to change the clock face.
Let me know what are the options that you see on the Settings app of your Fitbit device.
I'll be around.
04-28-2022 17:33
04-28-2022 17:33
ok, if this is a best answer, how do you change it to "normal setting"?
04-28-2022 17:35
04-28-2022 17:35
saying sorry, we're aware its not bright enough does not address the sudden change from readable to too dim to read. is there a fix for that?
04-28-2022 17:50
04-28-2022 17:50
using the above methodology, the screen does brighten to barely readable. Yet the smiley face changes to a clearly "normal" level of brightness. Then when you reconnect is, it goes to the medium brightness, being:
-low brightness, what i was experiencing, barely readable, not practical
-medium brightness, what it is now,
-normal brightness, what it should be, and what the smiley face is momentarily, and what it started as.
04-29-2022 06:04
04-29-2022 06:04
Bei meiner leider auch nicht. An wen kann ich mich da wenden?
12-01-2022 10:52
12-01-2022 10:52
Hi there,
I am having the same dark screen issue with my charge3. It started a few months ago with being unable to read the display during the day, now it can't even be read at night in a dark room. I have tried all your 'fixes' to no avail. The watch still connects to the app and the app data works fine, I just can't see anything on the screen. Kinda pointless now I'm having to wear 2 watches or leave the fitbit at home.
Anyother ideas on how to fix?
Thanks
