01-01-2016
21:53
20:42
01-01-2016
21:53
20:42
Hello Andrew,
I was just gifted a fit bit Charge HR and I love it! I went for a nice long run, but for some reason, when I logged into the website, the distance shows N/A.
Can you help me get this sorted?
I really need to see the distance I run every time.
Thank you.
Lourdes
Moderator edit: edited title for clarity
01-02-2016 05:29
01-02-2016 05:29
@curlyqluliWelcome to the Community! Great to see you seeking out help from other peers! Happy to have you here!
Congratulations on the new Charge HR! That's my favorite tracker wear! It sounds like you went for your long run but didn't press and hold the button to start the timer at the beginning of your run and pressed and held it to stop the timer at the end of your run. As that didn't occur, the Charge HR used our SmartTrack feature to automatically detect your run instead!
SmartTrack activities do not include distance. I recommend checking out my post here in regards to how SmartTrack activities are logged and how to log your activities if you'd like to see distance as a metric for your activity. Hope this helps!
02-09-2016 22:50
02-09-2016 22:50
Hey,
I tracked a workout, pressed the button to start as always and ended it after it was done. The screen showed me all the stats after the workout, as it always does.
However when I look online or in the app, it doesn't show any of my distances even as the screen did show them. I'm really annoyed by this, please help me solve this.
02-09-2016 23:17 - edited 02-09-2016 23:19
I am having the same problem. I did a 5K last night and knew that the course distance was shorter than the one I did in January, so I went to find the distance for both times and it shows N/A. I did use the timer both times and when I completed each run the distance was shown on the tracker. It know the course was shorter because it did log the steps, but didn't save the distance. Super frustrating!
Edit: It seems to be working now. I guess it was just being fussy. It took about 10 minutes before it updated!
02-10-2016 02:44
02-10-2016 02:44
Hi, @SunsetRunner, distance will not show if you edit the name of your workout to "soccer". It will only show if you rename your workout to "walk" , "run" or "hike". If you would like to see distance for soccer and other activities, you might want to vote for this feature request .
02-10-2016 08:00
02-10-2016 08:00
02-10-2016 08:19
02-10-2016 08:19
02-11-2016 12:56
02-11-2016 12:56
02-11-2016 13:00
02-11-2016 13:00
02-11-2016 13:27
02-11-2016 13:27
02-11-2016 13:36
02-11-2016 13:36
Technically, you paid for the tracker. The web service is free unless you have a Premium account. I get what you mean, however, but this is the way it works at the moment. As already suggested, the Features Requests board is the main way of communicating any desires for functionality changes.
Mike | London, UK
Blaze, Surge, Charge 2, Charge, Flex 2 - iPad Air 2, Nokia Lumia 925 (Deceased), iPhone 6
02-11-2016 13:41
02-11-2016 13:41
02-12-2016 00:18
02-12-2016 00:18
02-12-2016 02:33
02-12-2016 02:33
02-12-2016 13:11
02-12-2016 13:11
02-12-2016 13:19
02-12-2016 13:19
Mike | London, UK
02-13-2016 13:01
02-13-2016 13:01
@SunsetRunner "Workouts" with exercise mode on Charge HR don't display distance and pace information by default. To see distance and pace, you need to recategorize the workout to one of the following exercises:
Walk
Run
Hike
If distance is a metric that you'd like to see, I recommend recording a GPS activity using MobileRun as all activities logged with GPS will display Distance and Pace.
05-20-2017 12:46
05-20-2017 12:46
Same issue.
#1 reason purchased Fitbit HR this month was to track distance.
1) How did you press the button the HR to begin tracking a session?
2) I have manually changed the automatically tracked sports activities on my computer to 'Hike' however the distance still remains N/A
Thanks
05-20-2017 13:02
05-20-2017 13:02
@djmurray. automatically tracked (SmartTrack) activities will NOT show distance for hike, run, walk -- any activity. If you would like this to change, please vote for this feature request. (You can also add comments). I think most people would like to see distance, and yet the feature request doesn't have many votes, so Fitbit is not likely to change this without a LOT more votes!
You might be able to get distance for your activities, depending on which Fitbit you have, if your Fitbit has the ability to manually track activities (using the button). For instructions on how to do this, you will need to say which model you have (Fitbit HR is not enough information)
05-21-2017 02:21
05-21-2017 02:21
Thanks, Julia.
I have new the new Fitbit Alta HR.
I now understand smart track will not automatically give a distance.
However, I was told if you manually amend this activity to 'Hike' it will calculate the distance. But this has not worked.
How do I manually track activities with the Fitbit Alta HR? Where is the button?
