06-24-2019
22:16
15:06
06-24-2019
22:16
15:06
My Fitbit was recording in kilometres (as it should since I am in Canada) but it has now flipped to miles. I cannot find a way to change it back. Any help appreciated
06-25-2019 00:35
06-25-2019 00:35
You can do this via the web interface at https://www.fitbit.com/settings/profile
Change the "length" unit setting from "feet/inches" to "centimetres". Once changed and saved, the next time you sync your fitbit will be updated
Best Answer06-25-2019 07:15
06-25-2019 07:15
I am wanting to keep feet/inches (again, what I had before) but use kilometres for distance
Best Answer06-25-2019 07:19
06-25-2019 07:19
Unfortunately, the settings only allow for a choice of metric or imperial that apply to all distances. I'm not sure how you managed to get round this before and don't know how you can set it up that way again
