07-05-2017
13:53
09:26
07-05-2017
13:53
09:26
I entered my daily food log on the wrong day. Can the date be changed or do I have to delete and start over gain?
It's nice to see you around the forums, welcome @lulu1! Actually, you cannot edit the date of the food log but delete it and re-log it again.
To delete a food entry:
Hope this helps, let me know how it goes!
still having trouble. can you you take me step by step to add a meal
I’m afraid this solution didn’t work. I press and hold the listing, which then brings me to the details page, but I cannot delete the item.
It would be easier & less frustrating if we could go into each food item & instead of hitting the delete option, being able to alter the date of that item (which is located just above the delete option, but is "grayed out" & not functional).
That does not work. I have tried doing that on both my iPad and my iPhone. No luck. How do I delete an item I wound up not eating? I have changed it to 0 on the amount? (On some foods that doesn’t work - it still even shows up like 1/20th of the food. I want the item off the food log for that day. Help!
Best AnswerThis does not work. All I want to do is delete a food I entered by mistake so I can remove the calories. I have a Fitbit 2 which is an older model but just received it as a gift. Has anyone figured this out?
Same here. I’m holding it and it does not work. Now my log food is messed up.
Best AnswerActually, you click on the item you want to delete and it takes you to that items log/edit page and you see three dots in the top right corner and click on that and delete it
