09-27-2016
13:23
10:26
09-27-2016
13:23
10:26
For some reason my charge2 stopped tracking exercise. It last recorded something on the 25th. However, the active minutes records correctly as does the heart rate. I can confirm it is syncing without a problem, I am not sure if I am doing something wrong.
09-27-2016 13:33
09-27-2016 13:33
I am having the same problem
Best Answer09-27-2016 15:23
09-27-2016 15:23
@Da5id I'd recommend making sure that you are that the Connected GPS requirements listed here are all met.
I'd also recommend making sure that you've enabled location services on your mobile device and that you've given permission for the Fitbit App to use your location services.
@edyeseay I'd recommend re-pairing your Charge 2 to your account by using the replacement setup process mentioned here.
Hope this helps both of you get back on track!
09-27-2016 15:48
09-27-2016 15:48
Everything seems to be set up correctly.. Its not auto detecting my bike rides, I just changed the setting to log after 10 minutes instead of 15. I will see if that helps.
11-10-2016 05:03
11-10-2016 05:03
Hi,
I've been having the same problem too. My exercise was display on 20th October. The main dash is still registering exercise but not linking it to track exercise.
I have tried what you suggested to another member but I've found it no different....
Any ideas?
01-27-2017 23:51
01-27-2017 23:51
Mine has stopped same date. Cannot understand why. All other stats being collected except exercise. Very confused!
Best Answer01-28-2017 04:02
01-28-2017 04:02
I have the same problem - did anyone from fitbit reply? I dont understand why it needs GPS switched on for this? I had an original charge HR that didnt have GPS and always recognised my exercise?
Best Answer01-28-2017 05:11
01-28-2017 05:11
01-28-2017 06:50
01-28-2017 06:50
How how do you reboot it?
Best Answer01-28-2017 08:11
01-28-2017 08:11
Best Answer02-21-2018 12:31
02-21-2018 12:31
I have exactly the same problem. No exercise shown on dashboard since last Friday. Support told me I haven’t done enough for it to register but I’ve done more this week than ever.
Best Answer02-21-2018 15:20
02-21-2018 15:20
I still wear my Charge 2 but the exercise tracker rarely works. Every other feature works great (Active Minutes, Sleep, and Heart Rate).
I have tried all the suggestions several times but nothing has fixed it. My best advice is to use Mapmyride for tracking any rides or runs you go on.
02-24-2018 04:30
02-24-2018 04:30
Hey guys, @Da5id and @Debstf, I hope you are goin' well! 🙂 Let me ask you a few questions. What type of exercises are you doing? Are you using SmartTrack (the auto recognized feature) or are you using the Multisport (the exercises on the Charge 2 itself) to record your exercises? Are you using the connected GPS?
Keep me posted!
02-24-2018 05:13
02-24-2018 05:13
Best Answer02-24-2018 08:05
02-24-2018 08:05
Smart track needs to see a constant movement of at least X minutes, where X is what your settings are for.
To use GPS you still want to use the multisport mode and be carrying your phone with you.
02-26-2018 05:18
02-26-2018 05:18
Thanks for your reply @Debstf! For aerobics there is no option to use the connected GPS, however, for walk, you can perfectly use this feature. As my friend @Rich_Laue mentioned, you can use the Multisport mode, tap the screen until you get "walk", press and hold the button to start the activity and of course be carrying your phone with you.
This is how it shows when you are have the connected GPS between your phone and your Charge 2 working perfectly.
If you have questions about how to use the Multisport mode, you can review this article.
Let me know if you have further questions!
02-26-2018 07:30
02-26-2018 07:30
Well I am trying to use SmartTrack, I currently have it set to 10 minutes. I am either cycling, running, or playing basketball but it never picks up on that. The minutes active and heart rate show I have been working for 60 minutes, but the tracker does not count it as an active day.
I am connected to my GPS and Multisport works fine.
Best Answer02-27-2018 05:14
02-27-2018 05:14
Thanks for getting back to me @Da5id! You mentioned that you have tried several things to fix this, could you please tell me if you also tried to restart your Charge 2? If you haven't, please follow the instructions in this post to do so. Perform your activities as usual, but before you sync your tracker, please log out and log back in to your Fitbit account, finally you can sync.
Let me know how it goes!
04-13-2018 09:23
04-13-2018 09:23
this worked thanks
04-13-2018 09:55
04-13-2018 09:55
