11-21-2016
17:44
10:26
11-21-2016
17:44
10:26
11-22-2016 04:22 - edited 11-22-2016 04:23
It's nice to see you around the Community @Kkendall!
You own your data. Follow the instructions below to easily export your data to a Microsoft Excel (XLS) or comma separated value (CSV) file. CSV files can be opened by numerous applications, although most people choose to view them in a spreadsheet application such as Excel or Google Docs. CSV files automatically open in Excel if your computer has it installed.
All Fitbit customers can export four types of data:
To export data:
Hope this helps!
To export data:
Hope this helps!
11-27-2016 18:48
11-27-2016 18:48
Best Answer11-27-2016 18:50
11-27-2016 18:50
Best Answer11-28-2016 04:34
11-28-2016 04:34
I'm glad you found it @Kkendall! ![]()
Hope to see you participating in the Community more often since I think it would be awesome for you to explore our Community, so you can go ahead and log to any of the topics that might be of your interest in our Discussion boards. Feel free to comment and contribute with your knowledge and experience.
Have a wonderful week!
02-17-2019 03:29
02-17-2019 03:29
Quick question, can data also be exported as a PDF file?
Best Answer03-25-2019 13:49
03-25-2019 13:49
You would need to save your CSV file as a PDF.
@Kenzibit wrote:Quick question, can data also be exported as a PDF file?
Best Answer03-25-2019 13:50 - edited 03-25-2019 13:52
Can I also export the daily carb intake from this feature, or is it just for the calories ? Its useful to be able to map carbs to insulin dosage for Diabetics.
The CSV output has a column at the top for daily intake of calories, could you add a column for carbs ? I know its in the detail below but I will have to manually add it to the table at the top....
Best Answer03-27-2019 23:36
03-27-2019 23:36
From what I have heard and read, you can export everything apart from Hear Rate data to a CVS/PDF file. Don't know why they restrict us to our HR data.
