04-11-2020 14:44 - last edited on 09-17-2020 15:30 by
The time on the face of my Fitbit runs slow...approximately 14 minutes. How can I correct this?
Go to Fitbit.com and click on the gear icon at the upper right and then Settings. Scroll down to Time zone and set it correctly. Then scroll on down and click on Submit and then sync your tracker.
Thank you. Mine was only 5 mins slow but very irritating! Followed your advice and it worked! Many thanks
Best AnswerMy versa 2 is 2 hours and 10 minutes behind. How do I correct the time?
Best AnswerMy versa two is 2 hours and 10 minutes behind. How do I sync with my phone?
Best AnswerI have to sync my Fitbit 3 with my iPhone almost daily because it won’t keep correct time. Is there a better solution?
